Configures the timeout interval for RADIUS authentication requests.
| mgmt-access | Specifies the switch management RADIUS authentication server. |
| netlogin | Specifies the network login RADIUS authentication server. |
| primary | Primary server. |
| secondary | Secondary server. |
| index | RADIUS server index. |
| seconds | Specifies the number of seconds for authentication requests. Range is 1 to 240 seconds. |
The default is 3 seconds.
This command configures the timeout interval for RADIUS authentication requests. When the timeout has expired, another authentication attempt will be made. After three failed attempts to authenticate, the alternate server will be used. This only refers to the default configuration. After six failed attempts, local user authentication will be used.
The mgmt-access keyword specifies the RADIUS server used for switch management authentication.
The netlogin keyword specifies the RADIUS server used for network login authentication.
If you do not specify the mgmt-access or netlogin keywords, the timeout interval applies to both switch management and netlogin RADIUS servers.
This example assumes the default number of retries.configure radius timeout 10
The mgmt-access and netlogin keywords were added in ExtremeXOS 11.2.
